Cutting cat door into wooden door
Old 05-01-13, 08:02 AM
H
Hey everybody,
I am planning on cutting a cut door into a wooden door. I have researched a bit and have come up with either using a jigsaw or a grinder. What are your suggestions? Any help would be appreciated.
Thanks!
Old 05-01-13, 09:06 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
A grinder? That must have been for a metal door. A router maybe, but a jig saw will do just fine.
What kind of door? Solid wood? Hollow? Paneled or flat? Need to know so you don't cut a structural part of the door.
Old 05-01-13, 09:19 AM
P
Received 1,756 Upvotes on 1,569 Posts
Is this a cat door to the outside or between rooms within your home?
I would come in several inches from the bottom and edge of the door to leave solid wood around the perimeter for structural strength. Then mark out the hole you need to cut. Drill a hole somewhere inside the cut out area large enough for your jig saw blade to fit through. Then cut out your opening. For a hollow core door or a wood door with a veneer I would use a fine toothed blade but if the door is solid wood you can use a more aggressive tooth for faster cutting.
Old 05-01-13, 09:31 AM
H
That makes sense about the grinder, thanks. It's a hollow door with panels. It's in between rooms, not to the outside. Thanks for the help!
Old 05-01-13, 04:00 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
Are you sure it's made of wood? That sounds like a vinyl door.
Old 05-01-13, 05:11 PM
Gunguy45's Avatar
Super Moderator
Nash...I don't think you meant vinyl...but composite. Normally referred to as Masonite?
Old 05-01-13, 05:28 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
And, Dane, how did you guess it was between rooms???? Is that a North Carolina thing??
Old 05-01-13, 05:54 PM
G
Received 1 Upvote on 1 Post
Pet door frames are meant to be screwed into solid wood. A hollow door wont hold the screws and the inside of the door will be exposed. I have had success sneaking 1x wood into the hollow door to frame the opening. Secure the pieces with carpenters glue and brads. This might not work if your door has pressed panels to give it depth.
Old 05-01-13, 06:03 PM
Gunguy45's Avatar
Super Moderator
I modified a cat door because of the same reasons..used stainless machine screws and nuts. Think I had to drill and make little divots on the inside frame to hold the nuts.
Used vinyl cove moulding trimmed to width and caulk to fill in the hollow area. Have to get creative sometimes.
Old 05-01-13, 07:41 PM
Nashkat1's Avatar
Actually, I did mean vinyl. The interior doors in our house are a vinyl shell, molded to look like wood, that's hollow inside - or I think it is - in some places. So when the OP said
Originally Posted by herndog
It's a hollow door with panels,
that's what I thought of.
Our doors may have Masonite inside where the hinges and handle mount, but IDK (haven't had to take one apart). I think it's actually wood there. Is that what you mean by a composite door?
Old 05-02-13, 05:40 AM
P
I was asking if it was an entry or interior door to better gauge it's construction and to see if I should recommend an RFID locking door.
Old 05-02-13, 07:58 AM
Gunguy45's Avatar
Super Moderator
Nash...probably just a terminology thing, but I've never ever seen a vinyl interior door. What you describe is exactly what I mean by a composite. Almost the same material as pegboard or "hardboard", only much thinner and molded with a woodgrain. Older ones have solid wood perimeter frames but most have gone to a pressed wood or mdf type.
If you took a handle off you'd see what I mean.
Old 05-02-13, 12:47 PM
F
Not the best picture but this is what mine looks like. I did this more than ten years ago. The door is a hollow core and that heat-set fibrous material. As I recall the cat door was made with studs on this side and album screw receivers for the other side so it worked well, sort of a sandwich consisting of the frame-door-frame. I had to remove the flap as he refused to push it open with his head. Nonetheless the laundry room stays at least ten degrees cooler than the rest of the house so the cat door was a huge success over just removing the entire door. As I recall I used my Roto-Zip to cut out the hole and it was rather roughly cut.
Old 05-02-13, 03:24 PM
chandler's Avatar
RFID locking door.
Went by a concrete contractor's office/warehouse the other day to discuss things, when I hear this whirring noise and a German Shepherd emerged from the warehouse. He played around with us a while and went back to his door and it whirred open for him. First time I had seen one of those. How neat!!
Old 05-02-13, 04:16 PM
H
Thanks for all the great info everybody!
Old 05-03-13, 10:16 PM
Nashkat1's Avatar
OK, so we are talking about the same thing then.
This place was finaled out in 1989. I might take a look sometime, just out of curiosity.
