Accordian Door for Closet
frjeff's Avatar
MI
05-17-13, 03:59 AM   #1
I have a closet with a 22" finished door opening. Since it is on a wall 90 degrees to an entry door (where one can open into and bang the other), I believe I want to use an accordian door or a bi-fold door.
Unfortunately, it does not appear that I can trim 2" off of the bi-fold standard 24" door (stiles not wide enough). And, a quote for a custom made 22" pine louvered bi-fold is over $500.
So, an accordian may be the only answer. My question, can I place a 24" accordian door in this 22" opening? Or am I faced with another custom build situation?
joecaption1's Avatar
VA
05-17-13, 05:00 AM   #2
Or just reframe the opening so any standard door will work.
ray2047's Avatar
TX
05-17-13, 05:13 AM   #3
An accordion door only closes as far as the opening allows so yes it will work. Why did you think there would be a problem?
I can explain it to you, but I can't understand it for you.
frjeff's Avatar
MI
05-17-13, 05:18 AM   #4
I am just foolish, I guess. Plus, too many times in my life I've measured just once and cut - only to be wrong.
