Anderson window operator crank cover removal
Old 05-27-13, 10:31 AM
I have an 80's vintage window (don't know the model number) and was having trouble removing the crank cover without cracking it. Several searches didn't provide a good explanation so here is one. This cover is held with two screws but, once removed must still be carefully pried off. Insert a putty knife between the casement and the cover, then using a screwdriver or, better still, a very small pry tool, pry the center away from the casement. There is a single ridge that needs to be pried loose. See the attached photo highlighting the ridge.
Old 05-28-13, 03:09 PM
Temporarily Suspended
So what's the question? Is there some type of glue holding it besides the two screws? Try to score behind it with a utility knife.
Old 05-28-13, 04:19 PM
czizzi's Avatar
I think he is trying to give us a heads up. There is no question other than to save would be DIY'rs the pain of discovery he experienced.
Old 05-28-13, 06:28 PM
Ok, thanks for the info.
__________________
