door not sealed correctly
Received 0 Votes
so, my front door has a a big gap on the bottom side, it looks like the board on the door itself is worn out, not the frame, I'm attaching a picture.
Should I just replace the door? It's in good shape otherwise, is this enough to warrant a replacement, or is there a way to repair it? bugs and all sorts of things are getting in!
I agree...replacing the weatherstripping or adding a little wedge shaped seal (included with all new doors and normally available separately if you ask around) will probably fix the issue.
Received 0 Votes
841007 Endura Adhesive L-Shaped Corner Pad Wedge with Lip - Bronze All About Doors and Windows, Parts and Hardware
I found this link Jed that shows the wedge shaped seal. I don't endorse allaboutdoors.com but it gives you a reference. It looks like a good option for your door.
When I followed that link I saw what looked like weatherstripping that's mounted against the jamb. Nothing about the bottom of a door or a threshold. Am I missing something?
Jed, you might install an interior sweep as a temporary fix. Clear pictures will help us focus our answers better.
