What is the best tool to cut back expanding foam?
Hi all,
I recently covered the hole where a cat flap had been in my front door by screwing two aluminium plates on to either side of the door and filling the hole in between with Expanding Foam. The foam expanded just slightly too much (I must have marginally overfilled) which has caused the aluminium sheets to bulge slightly.
My question - if I temporarily remove the sheets to cut the foam back plush with the door, what is the best tool to use? I hear it's pretty tough stuff and also I don't want to remove the door when doing it.
FYI - I used this from: No Nonsense Fire Rated Expanding Foam Gun Grade 750ml | Screwfix.com
Many thanks in advance.
James
James
Hacksaw blade with the ends slightly bent to give you something to grip. Might scratch the door slightly, but you could put tape on the door to prevent that.
Wasn't even thinking right. Could just use a hacksaw and turn the blade 90 degrees on the frame....I think they all allow you to do that?
