Vinyl sliding patio door
Old 06-27-13, 12:12 PM
R
Our old sliding patio door is worn out...time to replace it. We are looking at Lowe's
"Reliabilt" model 300 vinyl sliding glass door. Vinyl on the outside & "composite" on the inside. We can't seem to get a straight answer as to what "composite" is. Particleboard ?? Is this considered "junk" in the building trade ? We considered an all aluminum door, but they are bad about conducting "cold". We considered "french" doors, but they won't work in our situation. Your input/suggestions would be most appreciated.
Thanks,
Roger
Old 06-27-13, 12:27 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Can't speak to that exact model...but if it says it can be stained or painted...normally composite means wood fibers in a chemical binder of some sort. Could also be fiberglass.
If it's a woodgrain look that is already finished...then it's just a vinyl product like the composite flooring.
Reliabilt isn't all that great a brand from what I've seen of them. Their entry doors seem to be ok, equivalent to Jeld-Wen, Stanley, or Masonite.
Old 06-27-13, 06:31 PM
And why will French doors not work?
Old 06-28-13, 02:17 PM
R
Just because of their swinging in or swinging out, otherwise I think they look great.
Old 06-28-13, 10:50 PM
D
Description of the Lowe's door seems to be Vinyl and nothing else with a limited lifetime warranty. 4.3 stars out of 5.
