Trap door hardware
goldberg1818's Avatar
PA
06-27-13, 06:33 AM   #1
Trap door hardware
Separated from door hinge for floor door questions.
It appears that if i put a regular hinge on the trap door, the trap door will pinch against the outside framing and not open up properly. Suggestions?
Nashkat1's Avatar
VA
06-28-13, 11:05 PM   #2
Welcome to the forums!
I've started a new thread for your question, so that replies to you won't be confused with replies to the earlier question.
I would use Soss hinges. They're invisible (no hinge pin above the floor), strong, and create less of a leaf effect. You might also want to taper, or slant, the side next to the pull.
