How to repair cracked PVC window frames?
Old 07-16-13, 05:42 AM
I picked up some used windows that are in great shape with the exception that the weld has failed in a couple of places. How can I repair these?
Old 07-16-13, 02:59 PM
XSleeper's Avatar
Look online for a product called "trimbonder". It's a white epoxy that glues pvc together. They make several kinds, you will likely want the 400 ml tube that fits on a standard caulking gun. You will also need several mixing nozzles. The stuff sets up pretty quick, so you have to work fast or the nozzles plug up.
Old 07-16-13, 05:24 PM
Good luck with that idea. If the frames crack the seal is broken and there going to fog up.
Should have been taken to the trash.
Trackbacks are On
Pingbacks are On
Refbacks are On
