stripped to much of oak door
Old 08-01-13, 10:57 PM
i was stripping off my oak door and i stripped to much off and chips came off. I put clear satin and you can still see the big gashes . Need to make it better .
Old 08-02-13, 02:23 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! How did you strip it? If you sanded it most likely you removed a good portion of the veneer. Is it possible for you to post pictures of what you did so we can see what you see? http://www.doityourself.com/forum/el...your-post.html
Old 08-02-13, 04:44 AM
Received 740 Upvotes on 646 Posts
Sure sounds like you removed pieces of the veneer It might be possible to use some wood filler on those spots coupled with some artistic painting/staining to get the repair acceptable. Pics would be nice.
If it's at the bottom of the door - would a kick plate hide the damage?
Old 08-02-13, 05:51 AM
stripping
i was stripping with chisel and it was dry and a couple chips came off. its on the middle of right side of the door.
Old 08-02-13, 10:14 AM
Received 1,187 Upvotes on 1,145 Posts
Ok, I have to ask - what were you stripping that required a chisel?
Pictures would help us propose suggestions, as has been stated.
Old 08-02-13, 11:02 AM
Filler and sanding may help but it might be time to paint that oak door
Old 08-02-13, 07:38 PM
i put degrease and was taking it off when it happened
Old 08-03-13, 03:57 AM
Can you post a pic or two? http://www.doityourself.com/forum/el...-pictures.html
It's hard for us to know what you have going on without seeing it? Why did you need a degreaser? wouldn't a wide putty knife have been better than a chisel?
