Re-glaze old Pella double-hung windows?
Old 09-09-13, 03:13 AM
Bought an old house a few months ago. The previous owner had installed Pella Proline wood-trimmed double-hung windows 20+ years ago. Practically all of them have the seemingly common butyl rubber eruptions here and there, particularly on south-facing windows that see most of the sun (I live in San Diego). Basically a grey putty-like substance oozes from the gap between the glass and the wood frame. Googling suggests that this is a rather common occurrence on these widows. I have cut away the excess and cleaned up the mess, and am getting ready to repaint. However, I am wondering whether I should do some type of reglazing before painting.
I called Pella and asked whether there is any recommended reglazing and they said no. However, looking at the contact line between the wood and the glass I see uneven coverage and apparent gaps here and there, so Pella's reply does not give me much comfort. Is there any corrective action I can take to prolong the life of the windows? This is not your typical old-style window with the broad glaze bead. If I were to try to reglaze I would need a very narrow bead, at most 1/8".
First post, please be gentle :-) Yes, I did search the archives and could not find an answer, hence the new thread.
Old 09-09-13, 04:09 AM
Received 120 Votes on 107 Posts
Welcome to the forums!
If there is a gap between the glazing and the glass, I'd consider filling it with a thin bead of caulk.
Pics might be helpful - http://www.doityourself.com/forum/el...-pictures.html
Old 09-09-13, 04:52 AM
XSleeper's Avatar
Received 195 Votes on 181 Posts
I'm surprised they said no. The exterior of the window likely needs a very fine bead of clear silicone. I would leave the inside alone. Trimming any excess should be sufficient.
Old 09-09-13, 04:54 AM
If that sash gets painted - don't use silicone! paint doesn't adhere well to pure silicone caulk, if it doesn't paint, then silicone caulk is a good choice.
Old 09-09-13, 11:32 AM
XSleeper's Avatar
Pella windows are usually aluminum clad exterior. And usually you shpould only use silicone against glass.
