Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Caulking/ weatherstripping around exterior of windows - Contractor??
Old 09-11-13, 08:44 AM
V
VMH
VMH is offline
Hello: We have a tall two story house and unfortunately I can see that the caulk that was put around the double hung windows is pulling away from the brick and in general failing on most of the windows. I need to find someone to remove the caulk, spray in the foam insulation, if necessary, and recaulk.
I am not sure which type of contractor to call for this type of work.
Thanks
Old 09-11-13, 10:20 AM
Received 331 Votes on 294 Posts
Possibly a handyman. The main thing is to make sure whoever does the work is competent - it's not easy to clean up spray foam or caulk off of the brick. It pays to do a nice neat job from the get go. Many painters can do the caulking, not sure how many would be willing to apply the spray foam. I assume the low expanding foam would be the type to use.
Old 09-11-13, 11:19 AM
XSleeper's Avatar
Received 722 Votes on 668 Posts
I agree. please don't spray foam the outside of the windows.. if you need backer rod before you calk that's a different product.
Old 09-11-13, 12:19 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
Any foam if needed would be applied from the inside after removing the casing. I would use a clear paintable window and door caulk so that the bricks don't get wasted from a poor caulking job. If you have to paint anyway, hire a painter or someone with decent brush skills.
