Need new interior doors but can't find
I have a house and also a duplex that needs some new interior doors since a few have large holes punched in them. They are about 15 years old. I can't find anything even close to them. They are just your cheap, flat, fake wood pattern in a light finish color. All I can find is either white raised 7 panel doors or unfinished wood veneer. I don't want to spend the time finishing the cheap wood veneer doors, I just want the cheap wood print style doors. Did they stop making natural wood finish doors? (no, I don't want the high end interior doors that are $200 a piece). This is for a rental and I also don't want to change all the doors in the unit just because 2 of them are bad. Can anybody point me to a store or website that may sell these? I just need the door and no the jamb but I will take them prehung if that's the only way they come.
six panel doors will come in white Premdor/Masonite or solid pine, that's about it. Other than a flat luan faced hollow core (about $85), the doors aren't going to be cheap, as the solid pine are running about $145 - 200
It sounds a little like the prefinished masonite doors that were popular in the 80's - 90's. I don't know if they still sell them. Pics would let us know for sure what you have - http://www.doityourself.com/forum/el...-pictures.html
Is it feasible to sway doors out so while they might not match, you'd have matching doors at opposing ends of the house.
Doors
Are these cheap enough?
Shop ReliaBilt 32-in x 80-in Flush Lauan Hollow Core Non-Bored Interior Slab Door at Lowes.com
My only affiation with Lowes is as a customer.
Hi, You want cheap and easy? I used to repair my own units. I had doors that had a finish like wood paneling. When a tenant punched a hole in the door, I patched the hole. Try to do that well or it will show. Then I covered the whole side of the door with shelf paper that had a wood pattern.It took two rolls they are 18" and the door was 30". It looked pretty good.
Good Luck Woodbutcher
