Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
installing a door on a 2x6 bolted th concerete
Old 12-15-13, 06:41 PM
hi
how do i install a a door on a 2x6 that is bolted to the concrete in the basement as part of a structural requirement and cannot be removed.
Old 12-15-13, 07:36 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! What is the measurement across the opening including the 2x6's. It should measure 2" wider than your door slab's measurement. A 36" door will fit in a 38" opening more or less. Bottom line the 2x6 stays, you install your door casing and door and trim it all,inside and out.
