Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Moisture Between Anderson Window Panes - Danger of Shattering?
Old 01-07-14, 01:35 PM
mcutugno
Question Moisture Between Anderson Window Panes - Danger of Shattering?
I have a large window over my front doorway that has a rainbow sheen between the panes when it is warmer out. I have been told that this is likely moisture between the panes. This rainbow spot gets larger in the summer and smaller during the winter.
Recently, with the extreme cold, the inside of the window appears to be frozen. See attached picture. Is this window in danger of shattering?
What can be done to get the moisture out (when it warms up). Does the window need to be replaced?
Old 01-07-14, 01:37 PM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
YES!
Maybe Anderson will warrant this.
Old 01-07-14, 01:40 PM
mcutugno
Yes it needs to be replaced, or yes it shattering is imminent? I will contact Anderson.
Old 01-07-14, 01:43 PM
Norm201's Avatar
I don't think it will shatter. There's no pressure involved. It might crack but even that is doubtful. It needs to be replaced.
Old 01-07-14, 01:45 PM
mcutugno
Some places mention that drilling a small hole into one of the panes allows the moisture to escape and clear the issue. Not sure if there are companies in NY that offer this service, but generally is this something worth trying?
Old 01-07-14, 01:55 PM
Norm201's Avatar
The problem is that the seal has been broken. Drilling a hole will not drain that small amount of "vapor". It will only allow more moisture to enter the cavity.
Old 01-07-14, 02:08 PM
czizzi's Avatar
Anderson has a 25 year warranty and will replace the glass for free. Not sure about the labor, but don't drill or do anything that will void that warranty. Contact them first for direction.
Old 01-08-14, 03:45 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Are you certain that it's an Andersen window? If so, when you call them, you will need the numbers and codes etched into the glass in one of the lower corners along with approximate dimensions.
Old 01-08-14, 05:03 AM
mcutugno
Upon closer inspection of the window, it may not actually be an Anderson window. The smaller casement windows and half moons above them all appear to be Anderson, but it looks like for the larger foyer and other arch windows, the builder used cheaper windows. There are no visible markings or codes etched anywhere on the glass.
Suggestions?
Old 01-08-14, 05:50 AM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
We would certainly need a better picture than that, if we had any hopes of identifying it. An outside picture of the frame might help. Something close up that would show a corner of the frame so that we can get an idea of what it looks like/what it's made of. You could look for any small writing between the glass on the aluminum spacer bar, although that doesn't always have anything meaningful on it either.
At any rate, even if it is not a name brand that is easily identifyable, it doesn't mean you can't replace the glass. the insulating glass unit (IGU) can be measured, can be made by almost any commercial city glass shop, then the old one can be removed and it can be replaced.
Old 01-09-14, 05:35 AM
johnam's Avatar
A close-up picture from the interior and exterior would help identify how the glass was installed. Hopefully the removable stops are on the inside since it looks like it high off the ground on the outside. The builder left a label on the glass, is this a recent installation? From what I can see by this photo, the spacer is Swiggle-strip, which Andersen doesn't use and the ice forming in the center indicates that the two panes of glass are touching or almost touching at that point. If you have no warranty then you must call a local glass shop.
Old 01-09-14, 06:32 PM
mcutugno
Thank you for the informative answer. THe label unfortunately is blank on both sides (from what I can see). Unfortunately it is not a recent installation (installed when house was built in 2006). That label has been annoying me ever since.
I couldnt get too close to that particular window because of the height, but I have another that I believe must be the same brand in my stairway. Attached are some close up shots of that. Not sure if that will help.
Old 01-09-14, 08:03 PM
XSleeper's Avatar
It appears that the glazing stops are on the interior. (a picture of the exterior would help verify that) It looks to be an aluminum frame window to me, (not vinyl) but I could be wrong- a better picture of the mitered corners would clear that up... but as far as a brand name is concerned, it's anyone's guess. Hopefully they will not bend or damage the top arched glazing stop as they remove it, because if they do you aren't going to be able to find a replacement... it will be impossible to replicate/replace.
Old 01-10-14, 05:28 AM
johnam's Avatar
You would think the builder would have used the same brand windows for the arched top dead lights but looking at the pictures, they don't look the same to me. What ever the case, you need a local glass shop to come out and give you an estimate for replacing the insulating glass unit first.
Old 01-10-14, 07:08 AM
mcutugno
I have two companies coming out over the weekend to have a look. What is the ballpark I should expect to replace a window of this size in NY? Is it only the glass itself that (should) have to be replaced?
Old 01-10-14, 07:27 PM
XSleeper's Avatar
IMO it would probably be between $300 and $400, assuming NY prices are maybe 20-25% higher than they are here. But I really can't say. Johnam's in NY so he will surely have a better estimate.
You have to figure that someone will need to come and measure it... (free estimates aren't really free) and also make a profit off the glass to cover overhead (even if they happen to mis-measure or break the first one... LOL) and then probably pay 2 guys both ways to drive who knows how far to put it in.
Installation shouldn't be any more than 1 or 2 hours, if all goes well.
Old 01-11-14, 05:28 AM
johnam's Avatar
If the arch is a true half circle, which it appears to be, the measurement is easy (no template required). It looks like it's about 3' X 3'. It will require 2 men, one on each side of the window. One side has removable stops the other has sealant that has to be cut away to remove the glass. Yes, the insulating glass unit is all that has to be replaced. Remember to get a written warranty. I would go with the higher end of XSleeper's estimate and that depends on where you are in NYS.
Old 01-11-14, 11:20 AM
mcutugno
So the size of the window is 67 1/4 across the bottom and 5 ft tall. The first estimate to replace just the glass came in at ~$2000. This was from a builder, so next I'll have a window shop in.
Old 01-11-14, 01:03 PM
XSleeper's Avatar
Ha Ha! I could fly out there first class and do it for less than that! Not that I'm offering, mind you.
Old 01-12-14, 04:33 AM
johnam's Avatar
I guess I was way off on the size since I had no reference to estimate the size. It has now become at least a 3 man job so that raises the cost and the size is almost twice what I thought. You should be able to get done by a glass shop for under $1000.00.
  #21
Old 01-13-14, 05:15 AM
mcutugno
Thank you for the updated estimate johnam. I'm going to have a few more places in before I make a decision.
  #22
Old 01-28-14, 04:54 AM
johnam's Avatar
It would be interesting to know if you got any additional estimates and what decision you have made.
