steel door
i am looking to install a benchmark fire rated solid steel door with metal frame. It is of the non prehung type. my ? concerns the thickness of the door frame 6 inches veruses my 2*4 walls. How should i compensate for this difference?
Thanks -----Josh
Thanks -----Josh
Frame for a pre-hung door for 2X4 walls is 4-9/16" wide. This 6" frame is 1-1/2" wider than that. How about casing the door with 2X4's, wrapped with 18 to 22 ga. sheetmetal?
Figured it had to be commercial. And now you know why you never see any OLD guys (30+) on a sheetrock delivery crew!! But in answer to your question, ask the bldg. inspector what he will and won't approve. Would hate to see you spend the time and money to do it one way just to have him say "rip it all out and do it some other way". It's been known to happen!
[Edited by lefty on 03-04-01 at 12:53]
Door
This may be a silly question but is this an exterior door?? These are not usually required to be fire rated. Also, what rating are they requiring on the door? The 6 " dimension you are talking about should be the outside dimension. It's the throat size which should be around 4 3/4" to accomodate 5/8" drywall on a standard stud wall. Measure the thickness of the material you need to cover (drywall. studs, exterior siding) and get the appropriate frame width for that because I doubt the inspector will compromise on the frame itself.
