Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Steel exterior door is sticking - but not rubbing
Old 02-05-14, 10:01 AM
A
Hi all,
Living in the cold of Canada, my exterior steel door that was installed in September is sticking, but has no signs of rubbing. All of the hinges are tight. The sticking almost feels like suction - it moves a bit when you try to open it, but you really need to yank at it to get it going. It closes no problem. Any ideas? I can post a video if this isn't clear.
Thanks so much!
Old 02-05-14, 10:05 AM
P
Received 1,776 Upvotes on 1,588 Posts
Does your door have magnetic weather stripping?
Old 02-05-14, 10:06 AM
Received 1 Upvote on 1 Post
Is there also a storm door?
Is there magnetic seal around the door?
Some seals have magnets built into the seals so they suck there self tight to the door.
Old 02-06-14, 01:53 PM
W
Received 13 Upvotes on 11 Posts
Hi, Try some wax (candle). Rub it on mating surfaces.
Good Luck Woodbutcher
Old 02-06-14, 03:44 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
Sounds like suction you would experience when pulling open a well sealed door when you have a good tight storm door.
Have someone hold the storm door open and see if there is any difference.
Could be the magnetic weatherstrip too.
