Basement window replacement....enlarge opening?
Our current basement windows are the standard single pane aluminum hopper, in a metal frame which was set in the poured foundation.
Since the current size is pretty odd (31 x 12.5) Im "stuck" with custom ordering. I dont mind doing so, I just havent found any half decent products that seem worth it. Lowes wants $116 per window, but the windows they are specing kind of stink (efficiency wise they are OK, but the weather strips are felt, hardware is really thin plastic, etc)
Was wondering if this seems like a nuts idea - what about cutting 2" from the bottom of the opening? The foundation is 8" thick, BUT the windows Im looking at are about 3" jamb depth, so I would go maybe 4" into the foundation instead of all 8". Then the remaining 4" that arent cut would serve as a stop for the new window. I would be cutting only from the bottom so as not to disturb the lentil at the top of the window. I will remove the sides and bottom of the existing metal frame, leaving the top alone (Ive removed one of these frames before, so I know I can do it).
Cutting the 2" gives me enough height for a 15" tall window, which is much more common and allows me to get a slider with better weatherstrip and hardware.
Does this seem feasible? Or should I just custom order and wait (FWIW, custom order for the existing size window only allows a hopper window)
Thanks.
-Chris
Thanks.
-Chris
Did you only look at custom windows from Lowes? Look for a place that just handles windows & doors.
Can you include a picture of the interior of your wall?
While I probably could find one, are there any other suggested alternatives?
I'd like to avoid running a gas saw indoors.... and I'm not sure there is enough room in the window well to go at it from the outside
Want to retain some venting and "we" dont prefer the look of glass block. I have a gb "window" on the unfinished side of the basement, with a small vent panel. WAF on using those again is low.
Id have to take out the existing steel frame either way (I did for the other one), at that point I could put in a 31x13 window (HD has that size on the shelf, go figure) but if I bumped the opening up to 31x15 is more visible glass *and* I can put in a slider instead of being forced to use a hopper.
