Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Install new construction window into wall + vinyl siding.
Old 04-14-14, 08:19 AM
maarkr's Avatar
Received 8 Votes on 6 Posts
Guess i'm just nervous about cutting a hole in the wall, etc. I built the interior framing and have the window. Here's my plan:
Drill holes in the corners of the frame area to the outside to use as a guide to cut the siding.
Go outside and scribe/cut between the holes to get the window area to size.
Remove some nails from the siding near the window so I can slide the window frame in underneath the siding.
Install window weather tacking inside/outside frame.
Remove the screen and sashes from the new window and fit frame under siding.
Level the base and fit spacers in loosely.
Tack frame in place and install the sashes.
Do final squaring up, nail fins in place, then check again.
Fit vinyl into exterior channel.
Finish insulating inside.
Q: Will cutting the vinyl to frame size allow me to slide the vinyl into the window vinyl groove? does it need to be a different size?
If there is foam under the siding, does the window go over that?
Any other suggestions or anything wrong with my plan?
Old 04-14-14, 12:48 PM
W
Received 20 Votes on 19 Posts
Window
A new construction window is supposed to be installed before the siding goes on.
Old 04-14-14, 04:42 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Estimate where the window will go on the outside and remove all the siding from that area by lifting it off the roofing nail heads. Don't remove the nails. Once the siding is off, you can cut your hole through the wall, install your window, flash it, apply your tyvek and window tape, then surround the window with jchannel if it is not provided by the window. Then you can reinstall your siding on the nail heads you left without losing positioning.
Old 04-14-14, 04:48 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
If this is vinyl siding, remove the vinyl siding in the entire area where the window will go. Use a Malco sideswiper siding unlock tool. Unhook the siding from the nails rather than pulling the nails. Then cut the rough opening out. If there is foam under the siding, yes, the window would generally go on top of the foam. Once you have the window installed, then you will cut the siding to fit back against the window, assuming you have an integral j-channel on this new window.
