Need help with finishing egress window
I am working on completely finishing my basement. When I purchased the house, the basement was partially finished (drywall walls up). There was already an egress window and drywall around it. Please see picture below. I am confused on how to finish/ trim this window. There are small gaps all around the window. So it is not butting up against the drywall. Also, there is a large amount of drywall wall above the window, which I haven't seen too often.
I am looking for some direction on what I need to do to fill the gaps between the wall and window and how best to make it look finished.
Thanks in advance.
Attachment 31327
Attachment 31328
Attachment 31329
Attachment 31330
Thanks in advance.
Attachment 31327
Attachment 31328
Attachment 31329
Attachment 31330
Can't see or open any of your links but i would guess you need to caulk the gap then cover it with base shoe, lattice, or some other appropriate sized trim.
Hopefully the photos show this time.
The gaps are not even and the biggest gap is on the right side measuring 1/2" at the top and about 3/8" at the bottom (not plumb at all).
The top and left are 1/4" - 3/8".
Thanks.
I'd cut and install casing or whatever wood trim works to fit, then caulk the cracks/joints. I like to cover the window seat with plywood and paint it to match the rest of the wood work. Even if the drywall seat is left as is, I like to coat it with enamel paint as that will help it look nice longer.
Thanks for the suggestion and quick reply.
Sorry the pictures don't look as good as what they did on my phone. I will turn the work light on tonight and get one more picture so it is easier to see.
It is strange to me that the cut-out for the window is taller than the window and there is so much drywall above it, I just wasn't sure how it would look with casing around the sides and top. I also didn't know what trim would fit the 1/4"-1/2" space. Is it common to see the cut-out that much larger than the window? (I'm just DIYer and haven't seen many in person, but the image searching I have done online, haven't turned up any.)
The window seat actually has a 1/2" marble top installed. It is not permanently attached yet though as I can slide it out if I need to.
I guess I will start looking to see what is available for thin wood trim.
Marble is a lot better than enamel painted wood
As long as the structure is solid, there really isn't any right/wrong way to frame out the aesthetics of the design. While that isn't the norm, I've painted similar - I suppose it boils down to what the customer or diyer wants.
Enameling the woodwork a contrasting color highlights the trim, using an enamel the same color as the walls will make it blend in more.
