Close limet switch for KEM window controler?
GreggerT's Avatar
WI
05-11-14, 09:15 AM   #1
Sorry....I may have missed it here but.....where is the close limit sensor for controllers like the KEM 140.......or maybe there is none and it's just resistance?
One of my skylights with a KEM 140 controller opens fine and motor stops as it should.....but on closure does not limit off....rather she just keep clicking at that closed position until I hit the stop button on the KES 310 panel. Ideas or suggestions welcome.
Thanks in advance.
NJ
05-11-14, 10:11 AM   #2
Welcome to the forums.
Gregger......
I don't believe there is a stop limit. I think the control board senses the increased current draw of the motor as the notification to disconnect power.
Chlemaire......
I would try a linear power supply for the $10-20 dollars it would cost. The original supply is a switching type and has been designed to run the board. You are trying to install a power supply not designed for that application.
chandler's Avatar
GA
05-11-14, 10:12 AM   #3
I started a new thread since the other one was 8 years old. You should have better exposure that way.
NJ
05-11-14, 10:55 AM   #4
Those gearboxes had problems. It sounds your may be on its way out. Treat it carefully as they are hard to find and costly.
