Stuck Pella Storm Door
Old 08-11-14, 08:55 AM
Hello
I have a Pella Storm door that is stuck in the closed position. I have taken the inside and outside handles off but don't know what to do from there.
is there something in the door that can be reached with a screwdriver to at least open the door ?
Old 08-11-14, 09:15 PM
Temporarily Suspended
Unscrew the piano hinge & rehang the door after you correct the lock problem.
Old 08-18-14, 12:42 PM
door is stuck in closed position... how do you get to the hinges in this case ?
Old 08-18-14, 01:47 PM
Gunguy45's Avatar
Super Moderator
Aren't the hinges on the outside? Most doors have a plastic snap on cover over the screw heads on the z-bar.
Old 08-18-14, 02:11 PM
XSleeper's Avatar
You would probably want to remove the screws from the latch side z-bar. The hinge side will have screws that you can't get to while the door is closed.
Old 08-18-14, 02:57 PM
Gunguy45's Avatar
Super Moderator
Crap that's right. Forgot about the ones behind the door. Problem may be if the latch or deadbolt was morticed into the trim, seen that a few times.
Old 08-18-14, 03:30 PM
XSleeper's Avatar
Yes... on Pella storm doors the mortise latch and deadbolt engage into a strike plate that is attached to the latch side z-bar. Sometimes the trim behind the z-bar is also notched, but hopefully it will pull open anyway.
