Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Fixing small slide-open glass windows in basement
Old 09-15-14, 04:59 AM
I've got several small sliding glass windows in my basement. There's one 12x12 that is fixed and then the other slides. The sliding portion is broken. Is there a way to remove the glass or this portion from the window so that I can replace or repair the glass?
Old 09-15-14, 05:31 AM
What type of material is the sash/frame made of? a pic might be helpful
Old 09-15-14, 05:53 AM
What's broken - the glass? If so, then it's likely you could just replace the IGU - we do that pretty commonly on our units when one gets broken or loses the seal.
Old 09-15-14, 09:34 AM
The sash is, I think, aluminum or something like that. The glass is what's broken.
Old 09-15-14, 09:37 AM
Yes, you could replace just the glass/IGU/whatever it is.
Old 09-15-14, 09:42 AM
XSleeper's Avatar
Pictures would help... can't see your window from here. but i think some of those single pane sliders need to be completely removed from the opening in order to get the sash out. you coyld see if there is a track you unscrew to get that sliding sash out. others simply lift upward until the bottom edge of the sliding sash can be tipped inward until the top comes out.
Old 09-15-14, 10:32 AM
Gunguy45's Avatar
Super Moderator
And there is sometimes a screw installed in the top to prevent sliders from being lifted out.
Old 09-15-14, 11:12 AM
I'll have to check tonight. Where do I take something like that to repair the glass?
Old 09-15-14, 11:22 AM
Look up glass shops in the phone book - they're around, you just haven't noticed them because you never needed one before now.
Old 09-15-14, 03:45 PM
Ok, well I went and checked, and I was wrong. It was not the part that moves, it's the part that is fixed. Any ideas on how to get that portion of the glass out for repair?
Old 09-15-14, 04:02 PM
Gunguy45's Avatar
Super Moderator
Sort of the same way normally. Should be some screws or brackets holding it in. Remove those and loosen any grunge or cut any caulk, slide it to the middle of the opening, lift and tilt.
Old 09-15-14, 04:51 PM
I see. Where are these screws located? I don't see them. The pane seems pretty fixed in there. I'll try to snap a photo a little later.
Old 09-15-14, 05:02 PM
Gunguy45's Avatar
Super Moderator
There may or may not be screws. Some have a bracket that snaps in, some (as mentioned) you almost need to take the frame apart. Some don't have anything and are just held by the latch against the other window. Years of crud and gunk can stick them pretty good.
Old 09-15-14, 08:19 PM
I went back down and tried to find some form of release. I don't really see anything there. The lip outside is metal. There is this plastic lip on the inside but I don't see a place to remove anything. Here is a picture. Is there a way to remove the glass?
Old 09-15-14, 08:40 PM
XSleeper's Avatar
A closeup of the glass edge, please. Inside and out.
Old 09-16-14, 04:35 AM
Ok. Here's some shots. I don't see a way to get the glass out. That's dirt on the other side BTW. It rained here.
Old 09-16-14, 05:28 AM
XSleeper's Avatar
The interior side of the window has the glazing strip. I believe it pushes into a kerf in the perimeter of the frame. Remove the tape and cardboard, and remove a small piece of broken glass. You should then be able to see that the exterior is solid aluminum (glass is probably glued to the outer part of the frame) while the inner side of the glass is held by a small removable strip.
You usually have to be really careful removing these or they will break. I'd recommend a very thin (thickness) putty knife, maybe like what you'd use to spot drywall nails. If you happen to break it, its not the end of the world since you can just silicone a new piece of glass in there and it won't fall out anytime soon.
Old 09-16-14, 05:49 AM
How do I get this glazing strip out and replace it?
Old 09-16-14, 07:00 AM
XSleeper's Avatar
The safest way would probably be to finish breaking the glass out... remove the broken bits... then those pieces should come out without much trouble. I just can't recall if they wrap around the glass completely.
Old 09-16-14, 07:04 AM
XSleeper's Avatar
That's why i suggested you look at the edge where the glass is already broken and missing. you should be able to figure it out by looking at it in that area where the glass has already been pulled out of the edge.
  #21
Yeah. I managed to get this plastic strip out, and it looks like it's held in with grey caulk on the other side. Came out with a heat gun pretty easily.
  #22
Old 09-16-14, 09:36 AM
XSleeper's Avatar
Nice job. trying to save and reuse old parts is usually quite difficult.
  #23
Old 09-16-14, 10:27 AM
Where can I get that strip material?
