Advice on exterior door jam?
Old 09-18-14, 08:18 PM
Z
Hi,
Our contractor was supposed to replace the exterior back door and jam as a part of a larger project. We just discovered that rather than replacing the jam and installing a prehung door, they chiseled out the old jam to make the new slab fit and applied plaster to cover the rough edge of the chiseled-out jam.
My question: how big of a problem is this? Will we need to tear out the door and old jam and install a new pre-hung set-up?
Thanks in advance for any advice.
Old 09-19-14, 02:50 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! It depends on how nicely they covered up the old marks. If it is ugly, and you don't want it, and paid for a door replacement, call them back to fix it correctly. Prehung door units are more expensive than slabs, but are much easier to install as a unit, IMO. It is not a structural problem, but being an exterior door, I question the sealing of the slab to the jamb. Could you post a couple of pictures so we can see what you see? Pictures of the jamb/hinge area as well as a straight on picture from inside and out. http://www.doityourself.com/forum/el...your-post.html
Old 09-19-14, 05:16 AM
Z
Thank you much! The contractor has been such a pain on so many issues that we don't want to deal with them anymore unless it's a structural issue... but it does look horrible.
Size:  19.1 KBName:  IMG_20140919_080412.jpg
Size:  23.4 KBName:  IMG_20140919_080335.jpg
Size:  28.2 KBName:  IMG_20140919_080446.jpg
Old 09-19-14, 05:33 AM
Norm201's Avatar
Received 354 Votes on 319 Posts
If you paid for a new prehung then you should get it. Personally I don't like the look of the repair job that was done. Wood filler and paint can go a long way to make it look decent. How long ago did this take place?
