New window in play house
David Mennenoh's Avatar
09-24-14, 08:30 AM   #1
Hi, I'm building a playhouse for my kids - the top having a closed in fort area. I want to add a couple windows, and found shed windows 12x18 for new construction with a nailing flange. Framing seems simple enough - I just have one question really. Regarding the rough opening, and then using shims... since there is no interior wall - so no trim or anything can I make the rough opening the exact size of the window - and then just slide it in, screw the flange in and be done? Any advice appreciated.
XSleeper's Avatar
NE
09-24-14, 10:58 AM   #2
You can do that, but you might want to cut the opening just 1/8" bigger so that you don't have to fight it when you put it in. (You do need a "little bit" of play) Be sure you use a level and a framing square to mark out the hole you will cut.
