shed window installation question
Received 0 Votes
I'm building a shed that will have one window on the side. I've got all the walls up and am ready to install the smartsiding panels. My question is do I put in the window before or after the siding? Sorry if thats a dumb question but I've never installed a window before. The window has a nailing flange, so do I simply put on the siding and cut out an opening for the window? does any part of the siding go over the window flange, or should I cut the siding back so that the entire window flange is exposed so I can nail it to the rough opening frame? I want to follow the standard practice but also want to make it easy if I ever had to change the window I would not have to pull off the siding. If someone could tell me what goes on first and if any part of the window is behind any part of the siding. Thanks in advance
Received 0 Votes
Thanks for the reply. Not sure what you mean on trimming window with brickmould or smarttrim? can you explain that? And also, I need to know how far back I cut the trim, do I cut it so it leaves the whole rough opening exposed, or do I cut the trim to fit the actual rough opening?
and is it possible that I can do this in a way where I don't actually have to install the window first? I still have a long way to go on the shed and was hoping that something so breakable could be put in last.
