How to install one way glass for exerior.
dhawald3's Avatar
Non-US
10-14-14, 04:02 AM   #1
How to install one way glass for exterior.
Hi,
I am planning to install one way glass on the exterior windows of my home primarily to reduce some of the heat entering.
The guy who is contracted to carry out the work suggested to install the windows with the mirror finish on the inside so as to prevent outside birds from pecking at their reflection on the window.
Will the orientation of the mirror surface effect the heat reflective property of the window?
lawrosa's Avatar
Super Moderator
NJ
10-14-14, 05:08 AM   #2
Is it common for birds in your area to peck at the glass??????
Mike NJ
"The problems that exist in the world today cannot be solved by the level of thinking that created them".
- Albert Einstein
stickshift's Avatar
WI
10-14-14, 05:28 AM   #3
Installing them that way would allow others to see into your home and you not to be able to see out.
I'd look for a different contractor.
marksr's Avatar
TN
10-14-14, 05:28 AM   #4
I once worked on a new house being built where they installed the 2 way glass per the homeowner's orders. They had to replace them with different glass [tinted] in short order! I was almost blinded on my 1st trip to that house, it was toward the end of the day and the low sun reflected off of the windows so bad you could barely negotiate the driveway!
retired painter/contractor avid DIYer
XSleeper's Avatar
NE
10-14-14, 07:29 AM   #5
What's wrong with low-e glass?
chandler's Avatar
GA
10-14-14, 07:54 AM   #6
OP is from India, so availability may be a problem, bur LoE is the way to go.
Gunguy45's Avatar
Super Moderator
AZ
10-14-14, 08:20 AM   #7
LoE and or tinted film would be much cheaper than replacing glass, unless it's new construction.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
dhawald3's Avatar
Non-US
10-16-14, 02:16 AM   #8
It is a new construction, I am living in a apartment on the second floor and I want to close off one of my gallery with sliding windows.
