doors not shutting correctly
Old 01-01-15, 07:56 PM
Z
Several of my upstairs doors have a similar problem but to different degrees. They don't fully evenly meet at the jam and two require pushing to fully shut. My bathroom door is the worst. The top of the door is 1/2" out of the jam on the latch side with the door fully closed. The bottom is flush against the jam.
My daughters doors is the opposite, but only about 1/4" out at the bottom. With a level I ran along the interior of the jam and it appears to be level all the way around.
How can I make these doors close correctly?
Old 01-02-15, 03:29 AM
Received 759 Upvotes on 664 Posts
Is there any play at the hinges? Often replacing one or two of the hinge to jamb screws with a longer screw [that will go into the stud] is all that is needed.
Old 01-02-15, 12:17 PM
Z
These doors only have top and bottom hinges and I don't see any play in the hinges. Also the doors aren't catching anywhere just almost like the door is warped, but I am wondering if the jam somewhere has shifted. It appears straight and level, but that could just be placebo.
Old 01-02-15, 12:32 PM
Received 1,198 Upvotes on 1,153 Posts
How long a level are you using?
Old 01-02-15, 12:50 PM
Z
1.5'
I have a 4' if that would be better.
Old 01-02-15, 01:01 PM
I would go longer - seems unlikely you would have multiple warped doors so I'm leaning toward the jambs being the problem.
Old 01-02-15, 01:28 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Don't forget, there are two plumb lines. One on the interior of the door facing and one on the wall facing. If either is out, your door won't close properly. Maybe sample pictures of the worst (not closeups) showing the places where it is rubbing would help.
Old 01-02-15, 01:38 PM
Z
It isn't rubbing at all, none of them are.
