Rotten exterior door framing
hello
I know there's good info about this subject all over here, but I didn't see this issue. if I took a good enough picture of the brickwork, you can see there's wood framing that goes into the slot that was left open. which now is rotted out and gone. i would love some suggestions how to make this repair. thx.
Personally, I think I'd pop off a few of the sill bricks and remortar them so that they have a nice 3/8"-1/2" gap between each of them. By the time you do that to 4 or 5 of them you will have spread the bricks out enough that you won't have any more gap... other than the same 3/8"-1/2" mortar joint that you should have on the ends.
As for the rotten wood above the brick sill, it looks like all you need to do is remove the storm door z-bar and replace the face trim. The sill nose looks fine. The board on the side of the bricks shouldn't even be there. A wider picture maybe would give us a better idea why its there.
took me too long but here is a shot from further away, and still looking for advice
slot shouldn't be there??? house built in 1974, original door, i think. thank you.
