Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Tight drywall fit around the door - good or bad?
Old 01-26-15, 03:46 PM
T
Is have a tight drywall fit up to the door jambs a good thing or bad? I recall reading something long ago that for a rough opening you don't want the 2x4 studs to be too tight against the window or door framing because then you might have problems opening and closing. Is the same true of drywall? Since, drywall is a finished surface I am not sure if this applies.
Old 01-26-15, 04:05 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Drywall won't expand or contract like wood will, so it is fine. Your trim molding will cover it anyway, so making it tight is really unnecessary, but not catastrophic.
Old 01-26-15, 04:33 PM
XSleeper's Avatar
Received 1,745 Upvotes on 1,569 Posts
If its tight against an exterior door it makes it impossible to insulate the door. If its already insulated then its no big deal.
Old 01-27-15, 04:05 AM
Received 755 Upvotes on 660 Posts
Normally the drywall is installed before the door and the drywall stops at the edge of the 2x but it shouldn't pose a problem if it's snug against the jamb. If the drywall is preventing the jamb from being nailed tightly to the stud [w/shims if needed] all you have to do is run a utility knife along the edge to trim off the excess drywall.
