replace glass and repair window? or whole new window needed?
had a large limb crash through my home window last night. must have been all the heavy snow here. its the middle of a triple window unit (not sure that's the correct terminology but the photo tells the story).
so was hoping to just get some new glass dropped in by a mobile glass place. already have some calls in. the glass looks to be 28 x 33.5. only top half of the double paned window glass broke. bottom sash's glass is ok.
that said.....now that I cleared the branches I can see the jamb or casing (again maybe not the right terms here - the plastic/vinyl parts the window slides up and down on...and the wood frame it fits into) on the bottom half only (the side parts on top half are fine) is smashed. so even though glass is ok up there...I wonder if I may end up having to replace the whole window. or if I can drop the glass in and get the crack in the wood frame fixed and the plastic parts replaced? photos attached.
and then if I do have the replace the whole window unit....since its part of a triple window unit....can I just do the middle? or whole unit has to be done?
thanks everyone.
thanks everyone.
I can't tell what brand of window it is... anything on the inside that would indicate the mfg? The broken plastic part is called the jamb liner.
thanks for the reply. I don't see any stamp or sticker or mark of any sort. glass places all asked the same thing. I looked all around. I know that doesn't help....
Look on the aluminum spacer (between the panes of glass) for anything etched. It's not common for mfg to put something there but also not unheard of. Check the lower corners of the glass for an etching. Maybe show us a closeup picture of the lock and handle.
I attached a photo of the lock if that helps.
this room was part of a 2004 add-on to a 1992 home, the prior owner did. so probably going to be hard to find these windows I would think.
I did find one small engraving on glass on one window only...looks like "TBP 12-95." not sure if that helps or if I am even reading it right.
Yeah that's a tough one. There are a LOT of window companies out there making generic looking windows like these. The 12-95 is surely the date of glass mfg. But there is nothing that says the TBP means anything as far as the brand of window is concerned. It was a long shot.
The lock is certainly circa 1995, it was used on a lot of windows of that age, even vinyl ones. My best guess would maybe be Weather Shield? Maybe someone out there will recognize it, but I sure don't.
