leaded glass pane popped loose
Old 03-25-15, 05:08 PM
I just discovered a pane in our leaded glass front door that is partially out. Nothing looks broken or cracked or damaged at all other than the glazing. I guess someone bumped into it and just pushed it out a bit on the top and one of the sides. The other two edges are still where they belong. Is this just a matter of wiggling the glass out (with the help of a utility knife), cleaning the glazing out with a knife and re-glazing it into place?
Old 03-26-15, 04:53 AM
johnam's Avatar
This may have some helpful hints on doing your repair: http://www.glasscampus.com/tutorials...s%20Repair.pdf
If the lead didn't bend, then carefully lifting the lead came slightly to clean out the glazing compound and resetting the glass should do it.
Old 03-26-15, 07:39 AM
Thank you. That seemed to confirm what I thought. And I especially liked the section on epoxy.
Most of my search efforts yielded the wrong type of information, but this is a good, simple resource that breaks it down the way I needed it to.
