Replacing Front Door
ptmuldoon's Avatar
NY
05-04-15, 07:26 PM   #1
I'm thinking of replacing our front (ugly) looking front door with something a bit nicer, and our current Front Door also has a storm door (that I do like).
I'm still looking at doors, and may just call someone to install it. But do you need to remove the storm door first before you can install the Front door?
XSleeper's Avatar
NE
05-04-15, 08:10 PM   #2
Yes..........................................
marksr's Avatar
TN
05-05-15, 03:37 AM   #3
X, if he's just replacing the slab does the storm door still need to be removed?
retired painter/contractor avid DIYer
Norm201's Avatar
NY
05-05-15, 03:52 AM   #4
No. but it will make the job a bit easier.
XSleeper's Avatar
NE
05-05-15, 06:25 AM   #5
99% of people who need to replace their doors need to replace the entire frame and the storm door has to come off in order to do that. I don't think he'd be asking the question if he was only replacing the slab since you don't have to take the storm door off to open a door or to take a door off its hinges.
marksr's Avatar
TN
05-05-15, 10:06 AM   #6
... see, there is a reason I mostly just paint
XSleeper's Avatar
NE
05-05-15, 04:54 PM   #7
LOL... you never know. It wouldn't be the first time I was jumping to a wrong conclusion!
Piddler's Avatar
MS
05-05-15, 09:37 PM   #8
Unless the new door hinges align and mesh perfectly with your old door, everything needs to be removed and replaced.
Norm201's Avatar
NY
05-06-15, 03:39 AM   #9
I've done several plank replacements on existing door frames. Careful measurements of hinge location onto new door is all that is needed. Use old door as a template laying it on top of new door. Then just transfer the hinge location. Using a chisel mortise out the cavity and you're good to go.
