Where to buy basement window around 40" x 32 "
Hello all,
My basement window is a double layer window. The inner layer is broken. Where can I buy the replacement window or I have to order the professional service?
thank you
thank you
To replace the sash and all you'd have to know who manufactured the window and then find out if you can buy a replacement. Most will just replace the glass unit which can be custom made at most glass shops.
Hello Marks,
Before posted the OP, I did searched the part number and none of them still exists.
Thank you for your info.
Any glass shop would be able to replace just the glass. It is probably a double pane unit, so they will need to come measure, order it, wait a week, then come put it in.
If there is any way you can remove the sash and take it to them, it would probably be less expensive for you.
Look in yellow pages for glass, city glass, commercial glass, etc.
