Twisted Metal Rod Coming out of Window
Old 08-01-15, 01:03 PM
Does anyone know the purpose of this metal rod and/or the correct technical name?
Can I just cut it off?
Thank YouName:  Window Rod Coming out of Window - 1.jpg
Size:  28.4 KBName:  Window Rod Coming out of Window - 2.jpg
Old 08-01-15, 01:13 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Welcome back. You twisted it!!!! Just kidding. That is the tensioning rod that guides your window up and down and it has an attachment that helps keep the window in a raised position. Obviously yours doesn't have that option. You can just unhook it from the lower left. If you should ever need to use that window again, you'll need a replacement along with the other parts that are missing.
Old 08-01-15, 01:40 PM
XSleeper's Avatar
Received 133 Votes on 125 Posts
Technical name is a spiral balance. Held by one screw at the top. Since yours is bent, its clearly shot. You generally replace them in pairs and need a tool to wind them... the color of plastic cap usually denotes the spring strength... 30 lb, 30 lb, 40 lb.
Old 08-01-15, 01:42 PM
Received 215 Votes on 204 Posts
That's a first for me..... I've never seen that on a window before.
Ok... just looked up spiral balance..... usually it's not seen when in operation.
Old 08-01-15, 04:24 PM
Received 24 Votes on 20 Posts
A spirial balance would not be mounted to the outside of the window.
It's made to go inside the window track and not be seen as mentioned.
Sure looks like a DIY attempt at trying to stop a break in.
