Prehung Smaller Door for Attic Access?
I could use help trying to figure something out. There are a couple attic access points inside of closets in my house. The doors are small - 24" W x 57" H, appear to not be hollow, and from the looks of it, are part of a prehung kit.
What I'd like to know is can I buy this size door in a prehung frame from Home Depot, Lowes, or somewhere else? Or do people tend to buy a 24"x80" prehung door and then just cut down both the door and the frame?
For reference, Pictures below show you the door, the frame from inside the attic, and the threshold.
I'm a painter, not a carpenter but on every job [new construction] I've been on when a short door like that was needed the carpenter cut down a full size prehung door/jamb to fit. What is it you want to do?
There have been a few cases where we have had the door dept at our supplier actually make us a custom sized door like tgat, but it's more likely to be as marksr said... either a standard prehung that has been cut down, or the carpenters got the individual parts and cut their own.
Received 38 Upvotes
Maybe I'm just lucky but I have a lumber yard nearby that specializes in making odd-sized pre-hung doors. Very good prices as well.
You might try looking in the Yellow Pages under doors. (Yes, I still use telephone books. )
Thanks for the info. So when you walk through one of those doors, it's a huge attic space. I'm going to frame in part of that attic to add some additional closet/storage space. But, I do want to retain access to the rest of the attic, and I figured doing a door similar to what's already there would look the best.
I don't have enough clearance to put in a full size door, so I'm just trying to figure out the simplest (and cheapest) way to add a smaller door without getting into custom jambs, etc. Any ideas?
Well, I guess I'm just wondering if there is some other non-door solution that I should be considering to give attic access through a closet?
You can make a face frame and use cabinet doors but then you would have to weatherstrip it... attics are both cold and hot so a real door cut to size is really the best option. Otherwise you have an air leak. If you get a prehung and cut it down you are stuck with the premortised hinge locations.
Received 38 Upvotes
Custom built costs extra...
