Replacing outside garage door
Old 12-14-15, 12:45 PM
B
Old door is rotted and flooding garage when it rains, have a new pre-hung metal door, but need to know if i can just pull siding off and re-nail it back on once new door is up?
I have shims, a can of spray insulation, caulking if needed, level etc, just need to know how to proceed with siding
Thanks for any help or advice !
Brandon
Old 12-14-15, 12:49 PM
P
Temporarily Suspended
You shouldn't have to touch the siding. Some pics might help.
Old 12-14-15, 01:21 PM
K
Normally the door will fit within the old siding trim, but if the door is really old, the new one could be an inch or so wider, in which case you would have to remove the siding to do a proper job. Just start at the top, and pull the nails as you work your way down, then reapply in reverse order. If the new door is narrower, you can either fill the gap with cualk if it is less than 1/2", or use wood filler strips around the door after the new one is in.
Old 12-14-15, 02:31 PM
Received 99 Votes on 87 Posts
Really need that picture of the outside of the door.
Need to figure out what caused the old door to rot out if you do not want it to happen again.
I like to use the newer style doors with composite at the bottom of the jambs and PVC brick molding so there is no more rot.
Old 12-14-15, 04:26 PM
Received 1,480 Votes on 1,368 Posts
Like mentioned..... a picture or two would be a big help. http://www.doityourself.com/forum/el...-pictures.html
Old 12-16-15, 08:42 AM
B
pics
here are some pics
Do i just pry the old metal piece out of the concrete?
Old 12-16-15, 08:51 AM
Should be just a few screws holding it in place.
The reason waters getting in is someone pored that stoop at the same height as the threshold.
About the best you can do is set the new threshold in a thick bed of silicone.
Old 12-16-15, 10:04 AM
B
i tried getting the screws out, they are pretty rusted, would prying it up work?
And i did get some waterproof caulking for after it goes in, seems straightforward after i get that piece up...
Old 12-16-15, 01:27 PM
B
update
got the bottom piece of with some grunt work just trying to remove the trim on the inside now.
What is the best way to remove old door frame? crowbar ?
Old 12-16-15, 01:30 PM
P
I usually cut the frames in half with a sawsall, on both sides before I use a crow bar.
Old 12-16-15, 02:38 PM
B
had to pry small nails out of the siding it is wrapped all the way to the door, as long as i cut that with the sawzall i should be good, luckily i still have one to use!
also should i put some weather stripping on the bottom of the new door to help with rain/water as well?
Old 12-16-15, 03:37 PM
P
Weather stripping is not water proof. It can't hurt as far as air flow goes.
Old 12-16-15, 07:54 PM
Any new prehung door will have a built in threshold with a seal, no added sealing needed at the bottom of the door.
