loose inside door
Old 04-10-01, 09:23 AM
Guest
I did the not-so-bright thing of hanging a shoe storage bag on the back of my bedroom door. Needless to say, the weight of it has loosened the hinge. I have tightened it so many times that the screw hole has stripped. Help!
Old 04-10-01, 06:33 PM
L
Received 1 Vote on 1 Post
After you remove the shoe rack, remove the screws from the stripped out holes. Use either a wooden match stick or toothpick to fill the hole. Glue the pieces in place and break them off flush with the door hinge. Then put the screw back into the hole.
