Hole in hollow door.
Old 01-10-16, 07:53 AM
Any ideas on how I can patch this door? I have seen a few videos on the subject but I am not sure how I am going to match the wood color. Any ideas?
Old 01-10-16, 09:22 AM
ray2047's Avatar
Best is replace the door. A slumlord patch might blend if you paint the whole door after patching
Old 01-10-16, 09:30 AM
Temporarily Suspended
Who got angry & did that? The first time I had a paint job, I went into a paint store said, I need something to patch some holes in a wall. The guy asked, Are they about the size of a fist? Yes, was the answer.
Anyway, I'm not a fan a Minwax but it might work, on that door.
Old 01-10-16, 09:56 AM
Handyone's Avatar
Hang a full length mirror on it or replace the door. Any reasonable attempts to fix the hole will look almost worse than the hole.
It's possible to replace the door skin only, but more trouble than it's worth.
Old 01-10-16, 10:12 AM
I agree, either replace the door or cover it with a mirror. The only way to patch it and keep the stained look would involve some expert faux painting - IMO not worth the effort.
Old 01-10-16, 10:59 AM
Well that is what I figured but I was hoping I could patch it somehow thanks for the responses. My three year old threw a coke bottle at the door I am surprised at how weak the door is. Anyways now I have to go out and try to find that exact door. Any suggestions on where to start?
Old 01-10-16, 11:09 AM
pugsl's Avatar
Any home store HD or Lowes, measure door size width and height.
Old 01-10-16, 01:01 PM
chandler's Avatar
If you want to fix it and looks are a lower priority, you can cut a 3" piece of luan the size of the diameter of the hole, insert a screw slightly into the wood at the 2/3 point, place hot glue on both ends of the patch and send it inside the hole, holding it with the screw against the inside of the door skin. Once the glue has dried sufficiently, remove the screw and use Minwax or other wood filler to patch over the hole area, sanding it smooth. It may take more than one application of filler. Once sanded smooth, it looks like painting the entire door or trying your hand at mini-staining would be in order.
Old 01-10-16, 01:17 PM
That is a birch door, not luan .... right ??
Old 01-10-16, 04:56 PM
Wow, I can only imagine if the Coca Cola bottle were one from the 50s. The door would have been totally demolished. A mirror is a great idea as long as the Coca Cola bottles are well hidden.
