Mitigating Lead paint on door and trim
Old 01-14-16, 11:18 AM
I recently bought an old house and have found that there lead paint on the interior doors (closets, bedrooms, etc.) as well as the surrounding door frames and trim. I've painted over other lead paint in the house, but I've read that I will need to do something else to mitigate the problem on areas of constant friction like the doors. Replacing the doors is probably not financially viable right now, so I'm looking for an alternative. I was thinking of just lining the door and door frame edges with heavy duty gorilla tape to eliminate the "paint on paint" rubbing. Obviously this tape would have to stay there permanently, so I'm a little hesitant. Any thoughts?
Old 01-14-16, 11:48 AM
Handyone's Avatar
Welcome.
Are there young children in the house? Lead is especially dangerous to infants and toddlers.
Any Lead Based Paint or suspected lead based should be left undisturbed.
I wouldn't consider a door rubbing as disturbance.
However
If the door rubs so bad as to cause flaking, or chips, or anything falling off the surface, it needs to be addressed promptly.
Old 01-14-16, 01:07 PM
Received 25 Votes on 21 Posts
Way over thinking this one.
If the door is rubbing because there's so many layers of paint what's it going to do if you make a mess covering it with tape?
The tapes just going to cause the door not to close.
Only time lead paints going to be an issue is if a kid chews on it or it becomes air born from sanding.
Old 01-14-16, 01:25 PM
czizzi's Avatar
Received 9 Votes on 7 Posts
Encapsulate with a good quality paint should calm your concerns. If the doors hang, take them outside and plane them down. Use a good quality mask that is rated for lead paint and make sure the neighbor kids are not outside. To minimize dust, you can use a hand/power planer that will chunk the wood instead of powderize it. Then a universal oil based primer and top coat of your choice.
Old 01-14-16, 01:46 PM
Received 120 Votes on 107 Posts
If the door sticks - it needs planing or adjusting. The door should never rub on the frame/jamb! Ideally you'd use a chemical stripper and remove the lead paint but as the others have said it's a lot easier to encapsulate the lead paint. About the only time encapsulation would be a concern is if the underlying paint isn't bonded well to the substrate.
Old 01-14-16, 02:04 PM
Handyone's Avatar
If you are concerned about lead in the home I would advise you to check out the EPA website.
Lead | US EPA
I'm California and EPA certified in lead renovation and abatement. From the EPA page, check out the PDF brochure "protecting your family".
You will see that most protective measures are common sense.
All of the advise above is good.
