old 1960s aluminum windows rattle every time i walk by them
I went up to them and when i push them they move back and forth like they are loose or have no cushioning to prevent them from rattling around back and forth. They are pretty old from 1960s anyway to resolve this without replacing all the windows in my condo?
Thats what the windows look like.
We're getting into two threads on this same subject. Can we keep it all in one? http://www.doityourself.com/forum/de...ated-cost.html
These are two totally different questions... ones on enclosing the balcony the other is dealing with rattling of the windows, they do have the same picture showing the window that is used throughout the condo.
OK, can we see the area in the other post showing the area where you want to install the windows? So far all we have seen is the windows in this post.
Those are the only photos i have at the moment when i get home i will take a picture of the opening, but the opening is almost exactly the width of that window in the picture just straight ahead 8 feet. I posted that picture so people can get an idea of what type of window is needed to be installed thats all.
You can put new pile weatherstrip in the sashes, but we would need to see a close up pic of the sash edge and frame.
Also, are the windows completely closed AND LOCKED?
Putting new pile weatherstrip on the sashes will make it fit tighter with less slop. (I'm assuming the weatherstrip on your sashes is shot.) Of course, if your sash corners are mitered, it might be difficult for you to DIY.
