96 x 80 door opening (Closet)
Received 0 Votes
Hello,
I have somewhat of a unique situation. I have a long closet opening of 96 inches wide by 80 inches tall. Before, there were 4 bi-fold closet doors installed, which looked really ugly IMO. I have taken those, and the sliding track down.
I would like to put 2 48 x 80 sliding doors in it's place. However, I am having a really difficult time finding 48 x 80 doors.
Can anyone point me in the right direction, please?
Or, if you have any other ideas for that opening, that is welcome also.
Thanks in advance!
Thanks in advance!
Any type of wood or composite doors would probably be difficult to get, but that's a not uncommon size for mirror doors. Yes, would have to special ordered, but it's a standard size IIRC. Problem might be the bottom track attachment. If you are on a slab or have carpeting, it can be a bit tricky.
Remember also, with sliders you can only access half the closet at a time. Maybe a different style of bifolds would work.
If the opening is really 96 wide you will need 49" doors to provide overlap or you will have a gap visible in the middle. Or you could build out the side jambs a little.
36" is the widest commonly available standard wood door. I'm sure you can order 48 from a lumberyard, but they will be expensive.
You can also get triple sliding tracks which would allow you to use 3 34 inch doors.
I have a similar wide closet in my basement and went with 2 bi-folds (4-24 wide doors). By using heavy duty hardware and 6 panel doors the look is a lot nicer than typical slab closet doors.
Received 0 Votes
Thank you all very much for the responses.
I have laminate on the floor.
It is exactly 96 inches wide.
3 doors isn't a bad idea, or a different bi-fold design.
I like the idea of mirror sliding doors, but hmmmmm.
Tough, expensive decisions, lol.
