Sagging bathroom door fix
Received 0 Votes
Hello everyone,
I need some help, I have a sagging bathroom door that I am trying to fix and I haven't had any luck getting it done. This is a pre-existing door that came with the house. What I observed about this door is that it only has TWO hinges and not THREE. The door is rubbing at the bottom and you can clearly see there is a gap at the top right of the door. I have replaced the hinges with new ones and installed 2" wood screws. The screws are not grabbing the stud and are turning. I am not sure if this is a result of using a drill and not a screw driver Yesterday I shimmed the bottom hinge with cardboard and that didn't work.
What else can I do?
What else can I do?
First I would try even longer screws on the top hinge. If that doesn't work/help, then you can either drill out the existing stripped out holes and glue in a piece of wood dowel, and then drill new pilot holes, or you can try the trick of coating wooden toothpicks with glue and jamming as many as possible into the screw hole and letting them dry. The reinsert the hinge screws.
http://www.doityourself.com/forum/el...-pictures.html
You might want to post a picture.
Yes, it's probably the top hinge screws. Replace at least one screw with a long one. Rub bar soap on the threads to make driving it in easier.
Also check the hinge side of the door and make sure it's parallel with the jamb and plumb.
IF you can lift the door and notice the top hinge move, then that is the issue. I use a golf tee glued into the old screw hole and then snapped off to set m new screws into. Longer screws can also pull the door jamb up tighter to the framing.
