Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Best way to Clean old 1960ish horizontal Aluminum sliding windows...
Old 08-12-16, 04:24 PM
K
Ok so i got this condo and the windows are super dirty very old aluminum windows, Im wondering what is the best way to give the windows and sliding balcony doors a good thorough cleaning. They also seems loose ont he track so any rumbling cases the windows to rattle (its not the glass loose withint he frame, its the fram hitting against the railing i guess you would say).
Also can i use wax to make them slide better? or what do i use after i clean the windows thoroughly.
Old 08-12-16, 04:34 PM
Received 85 Votes on 80 Posts
Really need a picture.
In most cases if there older windows you need to at least remove the whole door and inspect the rollers and replace if there worn out or sticking, then you can vacuum out the tracks.
Very common to have bad rollers.
Old 08-12-16, 04:41 PM
K
sorry not at home, but i dont think they have rollers, was planning on vacuuming out the tracks regardless. really clean it up.
Old 08-12-16, 04:42 PM
XSleeper's Avatar
Received 848 Votes on 777 Posts
Use a dry bristle brush to scrub off what dirt you can... blow the dirt out. Tgen once you have it fairly clean, use Simple green and a bristle brush. Don't oil anything, it will just attract dirt. Silicone spray is okay.
Old 08-12-16, 04:55 PM
K
will any all purpose cleaner work like comet? or does it specifically have to be simple green>
Old 08-12-16, 04:57 PM
XSleeper's Avatar
Don't use an abrasive. 409 or dish soap.
Old 08-12-16, 07:46 PM
Norm201's Avatar
Received 313 Votes on 282 Posts
Look for a metal polish like BRASSO.
You need new rollers. Yes it has rollers. Could be both top and bottom or just top or just bottom.
Old 08-12-16, 08:00 PM
XSleeper's Avatar
Lots of aluminum sliders do not have rollers. Some aren't much more than glorified storm windows... especially in warm climates like California where most are single paned. It should be obvious when you lift the sliding sash out if yours has rollers or not.
