Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Remove casement window crank while window is closed?
Old 11-20-16, 05:39 AM
Hi All,
I'm planning on doing some plastic insulation on my windows, and I realized that the casement crank will be jutting out and potentially cause problems.
First, for anyone who has used window insulator kits with these windows, does the crank complicate things? Second, if so, is it possible to remove the crank while the window is closed?
Thank you!
RJ
Old 11-20-16, 05:45 AM
Tolyn Ironhand's Avatar
Received 710 Upvotes on 603 Posts
There is a small set screw that holds the crank in place. Loosen that and just pull it off. Otherwise, you can wrap it with a bit of foam or a rag and the plastic will conform to the bump.
Old 11-20-16, 05:47 AM
Terrific, thank you - I'll give it a try.
Old 11-20-16, 05:58 AM
Received 755 Upvotes on 660 Posts
Make sure the set screw is still threaded up good - you don't want to loose any screws and have to hunt for a replacement.
Old 11-21-16, 05:50 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Do want to remove the crank or the entire operator? The operator can't be removed without opening the window.
