Help me identify door manufacturer
Old 01-11-17, 06:50 AM
F
I have a couple of steel exterior doors that I haven't been able to identify the manufacturer for. They both have "VIRGINIA" with an indecipherable logo stamped on the middle hinge. I've attached pics. I'm looking to get new weatherstripping for these doors and would like to order from the manufacturer if possible. Can anyone identify this manufacturer?
Thanks!
Attachment 75640
Attachment 75641
Attachment 75642
Old 01-11-17, 08:30 AM
XSleeper's Avatar
Received 903 Votes on 829 Posts
Please show us the door itself, the outer sill and the threshold under the door in particular. If you can pull down the door bottom weatherstripping and give us an end on view of the door bottom weatherstrip that might help as well.
The hinge itself does not tell you the door mfg, it only identifies the hinge mfg... in this case, Penrod. Penrod does not make doors, they make hardware, just like Truth hardware is used by a wide variety of window brands.
If you want help identifying a door, pictures of the door might help. If they have glass look in the bottom corners for a faint etching.
