Slide door knob is still loose?
I've my slide door knob but now the It is too loose and I tried to tighten up but it didn't work. My friend told me to put a little bit of carpet rug around the nut. Is it correct? or something else.
Is there a screw on the other side of that door where you could use a screwdriver to tighten it.
[QUOTE][Are you saying the hole in the door is wallowed out? if so, a washer may be enough to allow you to tighten up the knob. /QUOTE]
The knob is tight now Thx
