Gasket for window in front door.
Old 03-08-17, 06:59 AM
B
I have a Stanley front door. About 35 years old. The glass panel is most of the door. I have enclosed a picture of the gasket that I need. Could any one point me in the right direction to find one.
Old 03-08-17, 07:02 AM
XSleeper's Avatar
Received 1,584 Likes on 1,419 Posts
That's not a gasket, it's a plastic frame. You can probably order one at any box store millwork department or lumber yard if you know the size. (Overall width x height) Telling them the brand of door might help too. You would be wise to get the entire frame (both sides) and the glass assembly as one kit.
Old 03-08-17, 07:03 AM
You are talking about the plastic mullion, right? You might measure it and see if Stanley [or maybe another manufacture] has one that will work. Is it ok on the other side?
Old 03-08-17, 07:11 AM
It would have to be ordered directly from Stainley.
You can do it on line or any real lumber yard that's a Stanley dealer can do it for you.
Between the cost of the part and the shipping it may be time for a new door.
Before ordering one I'd check out Craig's list under materials.
Reason being people are replacing that style door all the time because the jambs have rotted out but the doors still good.
Old 03-08-17, 11:06 PM
Gunguy45's Avatar
Super Moderator
They are mostly made now by one of two companies that supply to pretty much all the door manufacturers. The profiles may be slightly different but they are usually interchangeable. Plastpro and ODL are the 2 big names. I believe ODL is the most common. Any number of sources online, or a local big box or lumberyard.
I noticed my local HD even stocks the most popular ones, prob due to the sun here, or maybe the meth heads?
Old 04-27-17, 07:56 AM
B
Gasket for front door
I have a front door that needs a new gasket around the glass in the center of the door. The door is about 35 years old. It is very good shape. From what I see the gasket holds and seals the glass to the door. Could I just use silicone to form a gasket on the door. It would be thick enough to hold and seal the glass. I could even use brown silicone to match the door.
Name:  GASKET FOR PA DOOR.jpg
Old 04-27-17, 08:28 AM
P
Received 1,629 Likes on 1,462 Posts
That doesn't look like a gasket. It's the plastic "molding" that forms the frame for the glass panel. I have never seen the plastic available as a replacement item as it comes as a part of the door though you could look for something vinyl or wood that would work as a replacement.
Old 04-27-17, 05:12 PM
XSleeper's Avatar
Why are you asking the exact same question again?
http://www.doityourself.com/forum/do...ml#post2608151
For a DIY'er I would recommend buying the frame and the glass, which will come preglazeded to the exterior side of the frame.
