Repairing damaged door
Old 08-13-17, 08:45 AM
A
Question Repairing damaged door
Need to repair a damaged interior door where there is a 4 inch jagged hole where the lock set once was located. The door is 86 inches tall and 35 inches wide (original to the c 1893 home) and replacing it with a new one is too expensive. It is made of douglas fir. Is there a type of wood epoxy strong enough to repair this kind of damage? The spot to be flled in is approx 4- 5 inches wide by 1 inch deep.
Old 08-13-17, 09:36 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Please post a picturer of the door.
Old 08-14-17, 09:06 AM
Received 94 Votes on 83 Posts
Will wait for the picture but it sounds like the defect is in an area which is structural and I don't think that will work. Additionally, unless the door is painted, don't expect the repair to blend.
Old 09-01-17, 04:15 PM
W
Received 12 Votes on 10 Posts
Hi, Check out a Door Sleeve. You can Repair the door then cover it with the Door Sleeve. They come in different sizes and back sets.
Good Luck
Woodbutcher
