type of wood for a window side jamb
Old 08-21-17, 08:07 AM
T
My window sill and part of the side jambs are rotted out. I got a 2x8 red cedar to use to replace the sill but what kind of wood for the side jamb? Can I use regular pine? Thanks
Old 08-21-17, 09:47 AM
P
Received 2,181 Upvotes on 1,951 Posts
What kind of wood is usually determined by availability for me. Untreated yellow pine could be a good side jamb.
When painting your repairs I'd start with a stain blocking oil based primer to prevent sap or wood tannins from soaking through.
Old 08-21-17, 10:34 AM
T
Thanks Pilot, I checked and I can get it here. It says it has to completely dry before painting, how long does that take?
Old 08-21-17, 11:51 AM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
Poplar or pine for jambs. Depending on whether it needs to be painted or stained.
Old 08-21-17, 02:14 PM
Received 840 Upvotes on 737 Posts
Depends on the wood. Has it been kiln dried? air dried or is it pressure treated.
Old 08-21-17, 05:13 PM
T
Marksr It is pressure treated..
Old 08-22-17, 02:55 AM
PT wood needs to dry out before you can successfully paint it. How long that takes depends both on how wet it was when nailed up and the environment it's exposed to. Usually that time frame is between 6 weeks and 6 months. Sorry I am unable to be more specific than that but that is the nature of pressure treated wood.
