Fix broken double glazed window
Old 11-03-17, 11:22 AM
Hi
I have a broken pane of glass at home see pics.
ive been quoted 100$ if I can get the frame to the local glass company. But it is 200$ extra call out charge.
Can anyone tell me how to get this glass frame out of the rest of the window?
And any other advice to fix this as cheap as possible?
Thank youJ
Old 11-03-17, 11:25 AM
Anyone recognise this type of window?
there are some type of screws or alann key type bolts on top that if I unscrew may release the pane but I'm not sure and it's hard to get at
Plus the Allan key head is not a regular one, so I have to try find something to fit it
Old 11-03-17, 04:50 PM
Received 99 Votes on 87 Posts
Just going to have to guess because I'm not there.
Sure looks like a double hung newer tip in window.
Should be able to just lift the sash, a little, unlock it at the top and tip it in and turn it sideways and the whole thing comes out.
The whole sash in most cases needs to be replaced, not just the glass.
Old 11-03-17, 05:16 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Like joe said...raise the sash about 4-6", slide the tilt locks on the top sides towards the latch, tilt the sash in to horizontal. Lift one side slightly (like twisting in the frame) and it should disengage from the balances and come right out. Reverse to re-install. If you still don't understand the directions, stop by any home center and ask them to demonstrate on a display. They all function pretty much the same.
I do disagree that the whole sash would need replacing. Most good glass shops can take the sash apart. Even if it's welded corners, they just cut them and bond them back together. They WILL have to order the glass, so you need to plan to cover the hole.
If you know the manufacturer and exact size, you CAN often order a sash, but it will probably take longer and cost more. May not even fit exactly due to manufacturing tolerances.
Old 11-03-17, 09:28 PM
C
Received 8 Votes on 7 Posts
When i replaced a window at our place, the window slides up and down on a square "rail" kind of protrusion that runs vertically on the frame. I removed the window by sliding a plastic putty knife in between the frame and the window. A credit card would probably work too. Pried out one side, then the other, and the window pulled out parallel to the floor, then worked the window out of the frame.
As GunGuy says, you'll need to cover the window opening while the window is at the glass shop. Good luck with it!
